i want to get a tool with which i can convert vob to mpeg . there is a prog called vob2mpg.but it is not working in my case. any other software plz.
				Results 1 to 9 of 9
	A VOB is a container for a MPEG-2 file. You just need to extract the MPEG-2. VOB2MPG is one easy way if you have the entire VIDEO_TS folder. Do you have the required .net files installed? Or you can use the older DVD Decrypter and rip the VIDEO_TS folder in file mode to MPEG files.
 But if you just have one VOB, just rename the extension to .mpg. Not the best method if you need subs or alternate languages, but it can work with simple VOBs.
 If you wanted to convert that VOB to MPEG-1, TMPGEnc Encoder can do that after it's extracted to MPEG-2. It's freeware for MPEG-1 conversions.
 Or some programs for DVD to VCD conversions are here: https://www.videohelp.com/tools/sections/dvd-to-vcd-svcd
 A couple of programs to look into are Eazy VCD or DVD2SVCD, both freeware.
	Assuming the VOB is a complete video clip you can use SUPER, (Simplified Universal Player Encoder & Renderer).
 However keep in mind that VOBs tend to be approx 1GB, so a video clip may start in one Vob and continue to the next.
 In a case like that you can use VOBMerge to join the individual VOBs into a single VOB and then use SUPER to convert to MPEG-2
 Note: Both of the above mentioned programs are freewareEveryone lies.
 The innocent lie because they don't want to be blamed for something they didn't do, and the guilty lie because they don't have any other choice.
	SUPER is in my book the very last resort, when everything else I've tried has failed. It may handle a lot of different and odd source formats, and can encode to a lot of different and odd formats, but more than makes up for its versatility with lack of quality. Reencoding a VOB to mpg would be like running whiskey thru a distiller just to get it out of a cask and into a bottle.
 /Mats
	When you mean "simple" VOB, it has to be as "simple" as possible. Even without subs, etc., some VOBs carry a "segmentation", particularly from DVRs and particularly if you had homemade chapters included, so a simple rename won't do - it will give you a broken file that doesn't cue.Originally Posted by redwudz
 However, just to test, play it in, for example, WMP and if it cues correctly at any point, then it's fine. If it's broken that means the whisky's salted and needs a more careful "distilling" - but you can easily rename it back to VOB and try something else.
 VOBs are tricky beasts. You need to run every one of them through an app to make sure sometimes.I hate VHS. I always did.
	Look at the original poster's country of origin. VCD is still big in India.Originally Posted by RabidDog
  Converting .MKV files with subs to DVD. Cant find a good tool.By anarchyx34 in forum MacReplies: 15Last Post: 25th Jan 2012, 12:05
  DVD Demuxer tool making 0kb .VOB filesBy Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 05:11
  a good tool for joining dvd vob files (which make up one single video) to gBy extent in forum Newbie / General discussionsReplies: 20Last Post: 23rd Jan 2009, 14:00
  a good tool for converting avi or divx to the dvd vob format?By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 14:37
  Converting PAL VOB FILES TO NTSC VOB FILES...By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
