I am trying to create a video file that will have a lot of text and will display on a 42" 1366x768 TV. What is the best way to get great text quality? My thought would be to create an avi file at 1366x768 (native resolution for the TV) and put it on a disc (divx?)
If my DVD player will play divx and I use an HDMI output to my tv, will it really display without scaling up or down?
Will this give me a sharper picture than using a standard 720 resolution or even 1080 where it would have to scale down?
Thanks,
OneMore
Will this give me a sharper picture than using a standard 720 resolution or even 1080 where it would have to scale down? -
Thanks for the help!
And from what I am understanding, even if the DVD player will upscale to 1080, it will not play a 1366x768 avi. If the file is 1366x768, will the dvd player just read it at 720 and then upscale to 768 to display correctly on the TV even though I am using an hdmi cable? Or will it output at 720 and the tv will do the conversion?
Last question on this, if it will upscale to 1080, why would it not upscale to 768 (native resolution for the tv)?
Thanks,
Onemore
And yes, it is widescreen. -
If the file is 1366x768, will the dvd player just read it at 720...
Last question on this, if it will upscale to 1080, why would it not upscale to 768 (native resolution for the tv)? -
Originally Posted by onemoreone234
http://www.ziova.com/
http://www.popcornhour.com/onlinestore/
http://www.z500series.com/
http://www.buffalotech.com/
http://www.tvixbox.com/
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
ac3 avi movies don't play back in 5.1 on divx dvd player
By funkyspaceman in forum AudioReplies: 10Last Post: 22nd Oct 2015, 16:01 -
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
DivX Player 6.82 cannot play AVI movie
By chuckycheese in forum Software PlayingReplies: 10Last Post: 24th Jul 2008, 22:10 -
Burning AVI file to DVD-RW to play on a Divx DVD player
By Jay8284 in forum Authoring (DVD)Replies: 4Last Post: 5th Jan 2008, 14:03
