After the compilation i found that i put the audio mistakenly. foe example there are three movis . i put the audio of movie #3 to movie #2. then after the compilation i checked with power dvd and find that there is a mismatch. then how can i re compile the dvd? is it necessary that first i delete the unwanted audio track adn add the correct one then to recompile? or any other short cut to do that? plz suggest. thanks in advance.
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 21:32 -
DVD Lab Pro Transitions question
By phatk9999 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 03:06 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 20:28 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 22:26 -
DVD Lab question
By rizay in forum ComputerReplies: 7Last Post: 7th Dec 2007, 19:13
