Ok i'm very newbie ....I have downloaded the movies. But im not sure what to do next. have zip program and converter i have read and i understand, but it;s not working for me. i really could use a lil help
someone to explain what im doing wrong or right
HELP
Kathy
	What kind of flies are these? dragonflies, fruitflies?
 You have been a member since 2006 and asked similar questions. You still not have answers?
 https://forum.videohelp.com/topic320942.html
 https://forum.videohelp.com/topic330250.html
 https://forum.videohelp.com/topic317914.html
	That's the problem with flies. If you don't solve the root problem they keep comming back....buzzzzzz.
	Depends on whats what
 If files are in rar achives , then zipgenius can unpack them
 Then it comes down to what was contained within , the guess would be some form of movie .
 Video's inside zip, rar, ace, are only good for password protection .
 Gspot is the first tool you should have, and provides internal information of avi's and others .
 Then in the case all is well , and decoders are installed , you then decide on what to do with it .
 Avi's comprising of xvid + mp3 can be burnt directly to cd , some home dvd players support mpeg4 play .
 Conversion to dvd :
 Avidemux, AVStoDVD, DVDforger, FAVC, or the old free vsoDivxToDVD .
 There is much more, but this should give you a start .
 And dont forget about imgburn, the best tool for burning to media.
	Hmm... I've been a member since 2002 and I don't have all the answers.  But that also doesn't answer the OPs questions, if he(she) finally states them all. But that also doesn't answer the OPs questions, if he(she) finally states them all.
 Try WinRAR first if you need to rejoin a bunch of files that might end in .r01 or similar, or the freeware 7-Zip should work. Then try ConvertXToDVD to convert to something you can play on a standalone DVD player. Freeware, maybe FAVC. And please do a bit of reading.
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
