Results 1 to 9 of 9
Read my blog here.
Once I find a codec what do I do with it. It said AC3 codec, I downloaded something called AC3 codec component but I don't know what to do with it.
depending on your container, the component has no effect (Perian codec will install it to you).
I rocks for avi with AC3 audio.
But don't work with MPEG (video + audio multiplexed) with ac3 audio (because Perian does not handle its decoding, it's made by Apple's mpeg2component).
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
short version, buy Apple's QT Mpeg-2 component.
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Apple mpeg2 component does not decode audio in AC3
The Monkees said s/he had no audio, so I doubt MPEG-2 video is the problem here. More likely this concerns an AVI with XviD/AC3.
The AC3 Codec Component is old (2004). One would be better off with the more recent (2007-07) A52 Codec component, which does roughly the same thing, but is more actively maintained, thus has better features and compatibility. If you do install it, remove the old one, so they don't conflict. -
sorry, I was thinking since iDVD was mentioned that it was an already
authored MPEG-2 stream, not an xvid file with ac3, since last I knew,
iDVD will not directly accept .avi files?"Everyone has to learn, so that they can one day teach."
Urban Mac User
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 01:05 -
MPG's in iDVD
By The Monkees in forum MacReplies: 12Last Post: 10th Jan 2008, 17:56 -
iDVD 6 - No audio track on burned DVD?
By KWagner in forum MacReplies: 1Last Post: 12th Sep 2007, 10:31 -
DVD created by iDVD doesn't contain audio when the footage is HDV
By vansrikanth in forum MacReplies: 1Last Post: 6th May 2007, 12:38
