Hi,
I'm not sure if i'm in the right forum or not - so my apologies if not. I have multiple mini DVDs (1.4 GB each) that I want to save onto a regular sized DVD for storage and to be able to play back onto a DVD player. I managed to save the mini DVDs to my harddrive, but now I'm stuck. I can't figure out how to burn them to a DVD. I have Nero 7. Is there some other software that I should be using? Please help.
You can use IMGBURN to create an Iso and then burn them to a dvd. You might need to rename the VTS folders to be in consecutive order; vts_1 , vts_2 etc. Did you want a menu aswell ? Or just storage?
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
I think nerovision that is included in nero can import from dvds. Or else use TMPgenc DVD Author as classfour says.
Jensen: It wont be a dvd-video. You must reauthor it if you want a dvd-video. -
Gotcha, my bad
Mini DVD tape: HD vs Regular vs HDV
By CliveJ in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2011, 20:34 -
Can you copy multiple mini-DVD discs to one standard DVD?
By darkcyber in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 2nd Jan 2011, 10:44 -
Perfect DVD copy with all the menu's but half the file size
By Kozanator in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2009, 10:44 -
What is a good price to copy Mini DVDs to DVD-5?
By Des in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2008, 13:54 -
Using AVCHD (1080i) instead of regular AVI-DV (480i) MINI-DV - argh!
By eddie24 in forum Video ConversionReplies: 4Last Post: 6th Oct 2008, 20:32
