I have a canopus advc300 that I'm quite happy with but I don't really use it enough to warrant the high price that I paid for it. I've just spotted a JVC miniDV/Svhs combo unit in a used hifi store (not sure of the model number) that can output standard vhs tapes through its dv firewire socket. The price is pretty reasonable and if I bought it, I could sell my canopus and be quids in.
What I want to know is if the capturing results will be as good as the canopus?
Are you certain that it outputs S-VHS through the IEEE-1394 port?Originally Posted by ereiamjh
The reviews I read never made that clear. It will dub DV to S-VHS.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I have the JVC unit. You can capture VHS/S-VHS through the firewire connection. Don't know how the quality compares to the Canopus, though.
Only problem I have is that the miniDV captures sometime have corrupt frames. Same tape captured through the camera has no corrupt frames.
Brainiac -
I have the JVC HR-DVS3U. It is a MiniDV and S-VHS combo VCR with a FireWire output. The single port DOES allow you to copy MiniDV or S-VHS/VHS to a DVD Recorder or other item through FireWire which allows for lossless copies. I do not know if other models allow this.
You're a smart cookie. 8)Originally Posted by ereiamjh
I do the same sort of thing myself, every now and then.Want my help? Ask here! (not via PM!)
Canopus ADVC300 - software?!
By Pixelrage in forum Capturing and VCRReplies: 21Last Post: 24th Dec 2010, 20:51 -
Considering a Canopus ADVC300 - further questions
By Pixelrage in forum Capturing and VCRReplies: 13Last Post: 1st Dec 2010, 13:36 -
Is the Canopus ADVC300 worth my investment?
By Ophelius in forum Capturing and VCRReplies: 7Last Post: 13th May 2010, 13:51 -
Volume Controls on a canopus ADVC300
By billycar in forum Capturing and VCRReplies: 8Last Post: 6th Apr 2010, 13:29 -
Canopus ADVC300 TBC question
By Valnar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 5th Jan 2009, 13:04
