Hi there people.
The problem is like this:
I have a movie file, encoded with xvid etc. and a sub file (let's say an .srt file).
Movie and subtitle 100% sync.
Now I want to edit the movie. To be more exactly, I wanna delete some scene from the avi. Let's say about 30 sec. after the first 10 minutes of playing and again 20 seconds after the first half of the movie(original movie length).
I've done this using virtualdub. It's easy.
BUT: Is there a way NOT to manually edit the srt file?Could this be done automatic? Is there a software that could delete some part of the movie and the subtitle file in the same time(rearranging the .srt file)?
The example above is relatively easy, but I need to edit movies cutting something like even 10/12 scenes and at this point doing everything manually is very hard.
Thank you and please excuse my English.
Subtitle Workshop would probably be the closest thing you'll find to do what you want with the least inconvenience. You will have to keep track of the EXACT time frames you cut out of each video and then SW can be used to automatically reduce the subtitle instances from that time stamp.
For instance, if you cut out 2m:33s:54ms at the 1h:12m:15s:30ms point of a movie, you just find the last subtitle prior to that time and choose to reduce all subtitles by 2m:33s:54ms after that point.
It's not completely automatic, but it's still better than manually editing all time stamps.theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
Ok. thanks. I'll keep that in mind. I'll try it at home. I'll post the result tomorrow.
But I'm still hoping that (someone/some soft) could do that automatic. That would be handy!
Thanks jkleslie. -
Well, if you're ALWAYS going to be showing the subtitles, you can "burn" them into the video.
Then it's part of the picture, and will be -- permanently -- fixed to the correct frames. -
Thanks AlanHK. I know perfectly that. But unfortunately I dislike that because
that require a lots of time spent. And i don't have that. So the question still remains. Gracias amigo anyway.
So... I've done it. I think that SW is the ultimate tool. Not perfect to solve my problem but a good tool.
a) I used VirtualDub(even that sometimes problem with audio vbr rate will occur) cut, note on paper the length of edit
b) In SW at the proper time/frame edit manually(delete the portion of sub) AND from that point applying a negative delay for the rest of the subtitle file. Save(optional).
c) Then move to the next point in VirtualDub and repeat the steps.
So... as U can imagine this is not very easy, but still might work.
THANK YOU ALL FOR YOUR ANSWERS. I HOPE THIS HELPS THE OTHERS.
AND -OF COURSE- THE QUESTION STILL REMAINS: Is there only one software that could do this automatic?
Bye.
How to Cut a scene using Avidemux 2.4
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 17:08 -
How to Cut out a scene in a movie using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2009, 08:49 -
How to convert DVD to AVI and cut out a scene?
By superJT in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2008, 15:03 -
How can i cut out a scene from a wmv?
By denadel in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 09:25 -
cut a scene using VirtualDub
By exon in forum EditingReplies: 3Last Post: 19th Jul 2007, 17:05
