I have an 5.1 AC3 file extracted from an MKV file. I also have the original MKV available if that helps. What I want to be able to do is convert the 5.1 AC3 into a six channel (5.1) AAC file. What do I need to put ffmpegX on to to make this work?
Cheers
Jason
ffmpegX does convert audio files to mp2, mp3 and ac3 as audio-only formats. Not to AAC.
Currently, ffmpegX movie conversions with AAC audio are mono or stereo, not 5.1.
To convert your MKV to MP4 with 5.1 AAC sound, you could use the VLC Streaming/Exporting Wizard.
To convert a DVD or VOB to MP4 with 5.1 AAC sound, you could use HandBrake.
To convert an AC3 5.1 file to AAC 5.1, you could export in QuickTime Pro to AIFF multichannel, then convert that to .mov with AAC 5.1 audio.
You can get Dolby Digital passthrough (optical port) on your Mac (Quicktime, VLC or Front Row), just like with DVDs, if you install Perian and do this modification. This trick is not for AppleTV, though.
help anyone? - AAC to AC3(5.1)
By pootler in forum MacReplies: 17Last Post: 13th Nov 2011, 22:52 -
AC3 to AAC Problem
By Shockpillow in forum AudioReplies: 1Last Post: 1st Sep 2010, 12:13 -
5.1 AAC to 5.1 AC3
By Kairo in forum AudioReplies: 6Last Post: 17th May 2010, 01:53 -
AC3 to AAC
By xQwerty in forum AudioReplies: 2Last Post: 15th Nov 2008, 13:05 -
aac and ac3
By ultraman36 in forum AudioReplies: 3Last Post: 27th Dec 2007, 10:38
