I already have my iMac connected via VGA to my my Plasma HDTV and know how to convert/burn/play them
using VisualHub,Toast,VLC etc... But I want the Aspect Ratio/Video to fill the screen on my HDTV(no black bars)..
Any ideas? I've tried 16:10 etc but I want the HD video to fill my HDTV screen(no black bars)...
Thanks![]()
HDTV is 1280x720 or 1920x1080, which is 16:9 (1:1.78).
So movies with an aspect ratio of 16:9 can always fill the screen without black bars.
Cinemascope movies are wider than that at 1:2.35. If you want to see those without letterbox bars, you'll have to crop off the sides.
Some plasmas have 1024x768 native resolution, so you may want to try 4:3 when used as a monitor. -
Then no aspect ratio will work for all videos. You'll have to use a player with stretch-to-fit function. But even this won't work for very wide screen DVDs. They have black bars as part of the picture and the player won't know to remove them.Originally Posted by iMacMan
Apple QuickTime 7.4.1
Full Screen Playback
Tired of pillar bars and letterboxes? Full screen playback, now included in the free QuickTime Player, has been enhanced to allow you to take full advantage of your computer’s widescreen display. Select from three different modes to fit your content to any size screen.
I just tried this and it works like a charm
How to play 4:3 Aspect ratio in fullscreen using VLC,MPCHC?
By skorpinok in forum Video ConversionReplies: 8Last Post: 3rd Sep 2011, 22:53 -
VLC 1.1.10 not playing MKV
By pooksahib in forum Software PlayingReplies: 2Last Post: 1st Jul 2011, 04:49 -
MKV File: QuickTime (With Perian) - Green Screen; VLC - No Problem
By Valentin in forum Software PlayingReplies: 2Last Post: 4th Aug 2010, 17:24 -
VLC DVD aspect ratio
By vhsreject in forum Software PlayingReplies: 3Last Post: 21st Sep 2009, 11:12 -
HDTV AVI aspect ratio
By cheerful in forum Software PlayingReplies: 21Last Post: 5th May 2007, 19:47
