How do i add watermark to my video ?
I added a watermark to video but the size increases up to 10 times than the actual file size!
Results 1 to 10 of 10
To add a watermark, you have to re-encode the video. I suspect you didn't use the same settings or codec as the original video, hence the change in size. Check the bitrate (And codec) of the original and the watermarked video with Gspot and you may see the problem. Generally, when I re-encode, I add some bitrate to somewhat make up for the lose of quality from re-encoding. But not ten times as much.
And welcome to our forums.
Maybe a stupid question, but I'm sure you folks will forgive me anyway if that's the case.
It's real simple with that link, or any editing package that you're familiar with, but is there anyway to add a watermark without re-encoding (to save time, and of course, quality)? I'm thinking there must be something that carefully "stamps" your video and doesn't touch the other pixels - something maybe commercial applications can benefit from I would think (ex: their logo).
Otherwise, if re-encoding is a must, then I totally agree with redwudz and the need to find the codec and the compensation of the extra little bitrate.I hate VHS. I always did. -
No. Not if you want it permanent.Originally Posted by PuzZLeR
TV and streaming is another beast, where station bugs and other stuff is overlayed as the video is transmitted. No reencoding is needed under those circumstances.
/Mats -
You could do it with a subtitle. If for DVD you could even make it a forced subtitle. But unless you're willing to do that, mats.hogberg gave you the answerbut is there anyway to add a watermark without re-encoding
Thanks for the response guys. Yup, those station IDs and even the DivX logo on playback are indeed a "soft" addition of a watermark when it's on playback/decoding/post processing/etc.
I do think it's possible still as a "hard" insert without re-encoding - but I'm thinking that if it does indeed exist we'd be talking about special effects software, with tons of processing and recreation of content/backgrounds/movement such as that used in advanced animation/etc. But that would be pretty much Hollywood domain.I hate VHS. I always did. -
The "tons of processing and recreation of content" WOULD be re-encoding.Originally Posted by PuzZLeR
You can do it as an overlay, and I think the only overlay that's (almost) universally supported is as a subtitle. -
Actually, you're correct. I was thinking along the lines of losslessness and overlooked the fact that re-encoding can be lossless with certain methods and codecs.The "tons of processing and recreation of content" WOULD be re-encoding.
What I should have said instead about the "tons of processing" is the gruntwork necessary to recreate every pixel losslessly, and exactly as it was before, but of course with a new layer on top of it. I'm sure this exists already for those with a multi-million dollar budget in Movie-Land, but regardless, in theory, it WOULD be re-encoding nonetheless.I hate VHS. I always did.
Watermark quandary....
By hd28qi in forum Newbie / General discussionsReplies: 12Last Post: 4th Feb 2011, 13:47 -
Watermark on videos?
By DVDHelpPlease in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2010, 23:18 -
how to watermark a stream?
By rooky in forum Video Streaming DownloadingReplies: 2Last Post: 25th May 2008, 15:22 -
Watermark on MP4
By zirkov in forum Newbie / General discussionsReplies: 0Last Post: 21st Feb 2008, 12:23 -
Help with Watermark program
By kokolo in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2007, 15:58
