hey guys im looking for an avi compression that captures atleast 7mbps of bitrate and up..i use virtual dub as a software and divx offers only a max of 4mbps and the other is at 6mbps, any one?
from my minidv and compress and save to avi at high bit rate 7mbps and up..
Results 1 to 12 of 12
Switch Divx's Certification Profile to Unconstrained. Even better, forget bitrates and use 1-Pass Quality Based encoding with a Quantizer of 2 or whatever quality you want.
tnx for the reply ,,can i use it with virtual dub? actually the 15 trial days of divx has been expire so i cant use it any more.
Yes, you can use all of Divx's main features in VirtualDub.
Divx often gives their software away for free. Just keep an eye on their web site. Especially around holidays.
Can't you continue using the codec after the 15 day trial period? Just with some limitations? -
with virtual dub divx is free forever but it limits the compression of only 4mbps of max bitrate, is there any software that can be a plug in for virtual dub?that offers a higher compression?
Originally Posted by nivek_nayr
is that divx version 6.7? where can i get that version? sorry for my ignorance, is there no possibilty to use in standard def?
Yes, it was Divx 6.7. But you don't need that particular version.
The HD profiles don't make the video HD. They're just different limits on settings like bitrate, frame size, etc. They are there to help you avoid encoding with settings that won't play on the intended devices.
I was able to get video bitrates over 30,000 with some Xvid settings (target quantizer 1, no b frames). -
if i download the latest version do you think it will change the settings mode in virtual dub that you can now maximize the bitrate higher than 4mbps?
Help: AVI compression using virtualdub
By stan101 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 21:55 -
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 21:41 -
Help with AVI compression.
By breeze9 in forum Video ConversionReplies: 6Last Post: 3rd Jan 2009, 02:06 -
ginormous avi (even after compression) What to do?
By hygieneboy in forum Authoring (VCD/SVCD)Replies: 6Last Post: 30th May 2008, 00:28 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
