    Feb 2004
    Australia
    I am converting some TV show DVDs I own to AVIs for travel purposes (I will watch them then delete, no need for any fancy stuff).
    I used DVD2AVI which gave me a video file (i used the xvid codec) and an AC3 or WAV file depending on which option I chose ( I mixed it up as I did a few episodes and chose different options).
    So I can play the files individually but need to know how to either mux them together or use a player that can let me choose an audio file to play along with a video file.
    As it took a while to encoded in the first place I was hoping not to have to go through more encoding to mux them together or can that be done creating a new file which simply combines them as opposed to reencodes them?
    In the future is it better to use a wav or ac3 file for this purpose?? AC3 was smaller so if it works, better.
  2. MPC will play an AVI file and a WAV, or MP2/3 file together automatically if they have the same name.
    You can mux them together with AviDemux or VirtualDubMod.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could also use a different tool to create the files, such as AutoGK. In which case you can convert the audio to mp3 and save more space for video quality.
    Google is your Friend
