  1. Are there any good free auto/bulk file renaming programs out there? Need something that can rename large numbers of pictures.
    USA
    Several free ones here: http://www.snapfiles.com/freeware/system/fwfilerename.html
    I use File Renamer, but it's about $20US: http://www.filerenamer.net/index.htm
  3. I use 1-4a Rename:
    http://www.1-4a.com/rename/
    It's freeware and you can configure it for basic mode or expert mode depending on your needs.
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  4. Member Soopafresh's Avatar
    Jan 2004
    I like Lupas File Renamer
    http://rename.lupasfreeware.org/
    Sep 2004
    Philadelphia, PA
    I have been using a program called Flash Renamer with good results. It is shareware.
    Steve W.
  6. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    irfanview
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  7. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Originally Posted by Xylob the Destroyer
    irfanview
    Agree, and renaming is just the tip of the iceberg. That's one application everyone should have. One of the benefits of the renaming component is if the images contain exif data you can rename them by date or any other info.
  8. Hey, thanks for all the help guys!
    I went with 1-4a Rename and it seems to be just what I need at the moment. Although i'm thinking I should check out that irfanview program as well.
    I appreciate all the help!
