I NEED HELP WITH NORCENT DVD PLAYER DP 300
TRAY KEEPS OPENING CLOSING, TRAY DISC ERROR.
I TRIED RESETTING BY PRESSING SETUP TO DEFAULT FACTORY SETTINGS AS PER NORCENT TECH REP.
IT USED TO WORK SPORADICALLY IF I MANUALLY PUSHED TRAY IN FAST AFTER 100 TIMES OF PUSHING TRAY BACK IN.
NOW IT JUST KEEPS OPENING AND CLOSING AND GIVEING ME TRAY DISC ERROR.
SERIAL NUMBER STARTS WITH HE113
CALL ME DAVE (631) 864-2656
STOP typing in all CAPS. It is the equivalent of yelling.
It is likely a failing/failed tray sensor. With the cost of current cheap players, it is much cheaper to replace it than have it repaired, unless it is still under warranty.Google is your Friend -
these morons at norcent refused to exchange or repair it. How much is a tray sensor. Is it difficult to install myself?
Call me 631-864-2656 -
Unplug it & plug it back in & see if this does anything. Not worth fixing. Buy a new one they aren't very expensive.
Toshiba SD-3990 DVD Player Tray Will Not Open
By TufrThanu in forum DVD & Blu-ray PlayersReplies: 13Last Post: 29th May 2016, 02:04 -
Panasonic S97 tray will not open
By southland66 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Nov 2011, 02:24 -
Harman Kardon DVD-22 won't open the disc tray
By edong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th May 2011, 17:11 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39 -
liteon disc tray will not open
By northy44 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Sep 2007, 08:20
