I have my 360 HDDVD drive attatched to my PC. When I installed the drive, it installed itself, and I didnt have to download any special drivers. When I view the device in Device Manager, it says the device is working correctly but shows it as a CD Drive.
I am able to play HD Dvd's using Power DVD but I am not able to look at the files on the DVD in Windows Explorer. I am also unable to play the DVDs using any other media player.
My trial period of Power DVD is running out soon and I would like to test some alternatives.
Anyone any ideas as to why the discs are recognised in PowerDVD but nothing else?
Make sure the drive has been assigned a drive letter. Go to the control panel and select administrative tools, then computer management. Once you are here, select disk management, and slide down and find the drive. Assign it a letter if it does not have one already.
Also make sure you have the right drivers installed, I don't think XP by default installs the correct drivers.
Try here: http://www.xbox-scene.com/xbox1data/sep/EEyFkZVEEyNPhTZIHr.phpGoogle is your Friend
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Xbox 360 drive replacement.
By Noahtuck in forum Off topicReplies: 2Last Post: 18th Dec 2009, 21:29 -
I can't believe I bought a used xbox 360 hd-dvd drive on ebay
By yoda313 in forum Off topicReplies: 46Last Post: 3rd Dec 2007, 17:25 -
XBox 360 HD Drive and HD-dvd - regions?
By elfranko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Nov 2007, 12:15 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06
