    Jun 2007
    I was wondering how to copy the main movie onto HD in one file and not in seperate 0.99GB parts, anyone know?
  2. I don't think it's possible,use DVD Decrypter(IFO mode and set file splitting to none).
    Another way is to use DVDShrink and untick file splitting.
    Jun 2007
    i tried dvd decryptor and it wont copy, the protection is new (Superbad)
    Oct 2005
    666th portal
    use shrink as moviegeek suggests, but use it on the files after dvdfab puts them on the hd.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    You can join the main movie vobs with vobmerge after you ripped also.
    Jun 2007
    does vobmerge compress the file? and are there noticeable breaks in the movie?
