Hi,
I want to convert the kids DVDs into DIVX files to save space on my mediacenter.
The specs from the dvd I want to convert are:
Video: 720x480, 29.97 fps, Pixel 10:11 (NTSC 4:3)
Audio: 48000, 2 ch
I'm simply want to convert them to divx, without changing anything, for tv playback.
I'm using TMPGEnc 4.0 Xpress, this thing is suppose to do everything automatically but I'm wondering if it sets the settings correctly:
1. The Aspect Ratio is set to "Pixel 1:1" do you thing I should change it to "Pixel 10:11 (NTSC 4:3)" to match the original movie on the DVD?
2. the framerate is set to "30 fps (Progressive)", the original is 29,97 ( not sure if progressive or not ) so I'm wondering if I should swtich this to "29.97 interlace" or "29.97 progressive" ?
Thanks a lot!
Thanks, will check AutoGk.
But I'm not sure why you suggest to resize? The Vod is 720x480 and when I play it on my tv it comes out ok so I was guessing as a divx it would be just the same?
When I play it on my tv, which is 16x9, it plays with the black bars on each side which I think it ok since a 4:3 ?
Thanks! -
ok...
Last question, do you know, when a NTSC dvd is 29.97 fps, is this 29.97 interlaced or progressive? Same question for PAL 25 fps ?
I should select the same as the source when doing my divx right? -
You almost never want to encode interlaced video with Divx in interlaced mode. Players don't really know what to do with it. You'll be better off with an inverse telecine (for film sources) or a deinterlace.
DVD to DivX Conversion - Recommended File Sizes
By DakotaThrice in forum Video ConversionReplies: 3Last Post: 13th Jun 2010, 07:31 -
Any recommended settings for TMPGencXpress color filter?
By Anonymous5394 in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 11:29 -
HDTV capture using Hauppauge 1212 - recommended settings?
By JamesNG in forum DVB / IPTVReplies: 0Last Post: 30th Dec 2008, 09:13 -
FLV to Avi or MPG, recommended settings?
By dzoni in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 15:27 -
Recommended software for DVD to DivX
By craigwojo in forum DVD RippingReplies: 6Last Post: 18th Feb 2008, 08:10
