Closed Thread
    Feb 2008
    i Ripped "POSEIDON" with Anydvdh to my harddrive , and i worked really good...
    but now i "see" 2 larger files .evo in in the folder where i put the ripped files...
    do i need to merge them before i evodemux them , or can i do that later on ???
    and how do i choose whitch subtitles to keep...???
  2. You should have something like feature 1 evo and feature 2 evo. When you use evodemux i believe its checked by default but under the options tab continue with next evo is checked. After the first evo it will go to the next evo
    Feb 2008
    ok... so i noticed... when tested , it continued with the "2nd" part of the movie... How about the subtitles then ???
    Please stop make new topics for your hddvd to bluray conversion. Continue in https://forum.videohelp.com/topic345583.html . Just reply to add information.
