Im having problems with the application "Absolute MP3 splitter" as soon as i hit it to start and operation i get a message "Access violation at adress 7C91OF29 in module ntdll.dll" Read of adress FF1BFD97" and it after crashes, have tested to reinstall and delete all references to the program without result, could it be a codec pack for instance thath perhaps could disturb here? is it an idea to uninstall such and test?
i take it thath "ntdll" is corrupted ore something? its a system file so it whas hard do delete it lol, this program has worked earlier..so its something with my current windows XP installation screwing up
did some googling and atleast found something describing something similar
http://www.ucap.biz/manuals/Error_Message_-_Crystal_Re-1.htm
and i have version 5.1.2600.2180, and i have SP2, and i dont want to download their service pack 3...i think?![]()
any?
re-install Xp and see if it works .
Scan your disk for surface errors.
re-seat all your memory chips (on the computer, not your own if you are a robot)
use a different application.
official service pack 3 not available yetCorned beef is now made to a higher standard than at any time in history.
Hm..i think i go for another software instead of reinstall Windows, cause its only this soft who are scewing, but thanks anyway, its not a whole world thread..just thath i like this soft, but truly there are others thath works pretty same
Has this SW worked on the computer with XP?
Have you installed anyother SW lately?
Does it work on another computer with XP?
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 18:55 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 18:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 01:40 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 09:34 -
DVDAuthorGUI - Status Access Violation
By ecc in forum Authoring (DVD)Replies: 13Last Post: 12th Dec 2007, 01:47
