Version: SVCD2DVD 2.5
Build: 2.5.3600.0
Type: System.FormatException
Source: mscorlib
Message: Input string was not in a correct format.
InnerException:
StackTrace: at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.String.System.IConvertible.ToInt32(IFormatP rovider provider)
at System.Convert.ToInt32(Object value)
at x3284ccece41ee22b.xfa6d102debc45529.x70c272251ba60 dde..ctor()
at x3284ccece41ee22b.xfa6d102debc45529..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
Any thoughts on the issue? Thanks for any help!
jen
Results 1 to 11 of 11
This is based on a different srror, but it's a starting point. Let us know what happens:
https://forum.videohelp.com/topic334156.html#1734407Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Hi, I tried entering the following text at the Windows XP command prompt, which it took.
Command Prompt Code:
regsvr32 "C:\program files\badgerit\svcd2dvd v2.5\code-lock.ocx"
Then I tried to start up the SVCD2DVD 2.5 again. This time an option for bugging details came up and I got this:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
at x3284ccece41ee22b.x210ff09a2516b1a7.x07267fbbae07d a13(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallba ckDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba ckHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Objec t userData)
at System.Runtime.CompilerServices.RuntimeHelpers.Exe cuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallba ck(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba cks()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SVCD2DVD
Assembly Version: 2.5.3600.0
Win32 Version: 2.5.3600.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/SVCD2DVD.exe
DevComponents.DotNetBar2
Assembly Version: 7.0.0.3
Win32 Version: 7.0.0.3
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/DevComponents.DotNetBar2.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2.5/Interop.CodeLock.DLL
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
This is more information than I got before. What exactly is the input string? Where is it stored and what format should it be in? Maybe I can manually edit it? Thanks!
Jen -
Maybe I should ask for a refund? I bought a SW program that won't even start up. Thoughts?
Did you try this part of the thread I referred you to?
https://forum.videohelp.com/topic334156.html#1734429Dwight
- Herm Albright
Hi there- I performed the following steps:
1. Run the command at the prompt: (successfully)
2. Installed VB runtime per these instructions:
http://www.microsoft.com/downloads/details.aspx?familyid=7B9BA261 ... laylang=en
3. Reinstalled SVCD2DVD 2.5
4. I ran a .NET v 2 repair as well.
5. I started up SVCD2DVD 2.5 and it had the same error.
(If I knew what the input string is, and what it should be, I could type in what it needs to be to make it startup).
I am running a standard Lenovo T61p.
Jen -
It would seem that the SVCD2DVD settings in the registry are causing the issue. Can you tell me what you have for TVOverscanPixels in HKEY_CURRENT_USER\Software\Badger I.T.\SVCD2DVD 2.5\Settings\Process :
[/url]
There is actually nothing in there... Weird. I've installed it twice now.
How can I force it to set the registry values? Thanks!
jen
Can you add a string key for now:
TVOverscanPixels
value 1
And lets see if that gets you any further?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
The program now starts correctly. Adding the Registry key did the trick. Thank you for all your help.
Now I just need to figure out how to use it!
Jen -
Thanks for the info!
Sony mini dvd fatal error
By spaski in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th Dec 2010, 22:05 -
SVCD2DVD crash on xp 64 bits
By alkirah in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Jan 2009, 09:17 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Gui for Dvd Author keeps giving fatal error
By BobT in forum Authoring (DVD)Replies: 23Last Post: 7th Sep 2007, 13:10 -
SVCD2DVD Crash with subtitle
By half-life in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd Jul 2007, 11:36
