I have an AVI captured from a Sony digital camera. I wanted to remove unwanted sounds from the audio track and used the Vdub filters Lowpass, Highpass and Gain. I processed the AVI and imported it into Vegas Studio 8c. Following that I imported the encoded file into DVD architect and created a DVD. When I play the DVD on the DVD player the clip of this audio filtered AVI looks awful. The moving figures leave trails behind them. Now I am looking for the culprit and of course I want to correct this problem. Luckily I still have the original version of the AVI. Could anyone help me please?
When you modify the audio, put Virtualdub in Video -> Direct Stream Copy. The video will not be touched at all.
As far as I can remember I placed audio to full processing and video to direct stream copy. In case by mistake I placed video to full processing, would that give such a bad result?
Putting video in Full Processing mode would have created a huge uncompressed RGB file (~100 GB/hr) unless you selected a compression codec. This also may have confused your MPEG encoder about the field order. That would have made the video play with a very fast jerkiness any time there was motion.
Thank you jagabo I believe you are right. I have compared the versions of the video clip before and after processing. There is obviously something wrong in the clip after applying the filters. I now shall use the original copy in DVD production and handle the audio part using audio envelopes of Vegas Studio 8c. Thanks again.
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Dilema ? Problem when converting video with audio track
By doward in forum ffmpegX general discussionReplies: 5Last Post: 1st Dec 2010, 14:32 -
Vdub choose audio track
By Soixante in forum EditingReplies: 2Last Post: 25th May 2008, 13:45 -
Video audio track cleaning problem
By efiste2 in forum AudioReplies: 1Last Post: 9th Feb 2008, 15:49 -
Vdub overlaying video track
By SearchQuality in forum EditingReplies: 0Last Post: 1st Dec 2007, 10:01
