Heres the situation, i have captured a VHS video on my CANOPUS ADVC100, then i used TMPGNc to convert it, So i know have a MPEG VIDEO file and a AUDIO WAV FILE, which goes great into TMPGnc DVD AUTHOR, BUT the audio has pulsing noise in it which sounds like its been picked up from the VHS player i used (its a 2.5 hour vid and it took hours to convert it so i dont really want to do it again). So i have used a program called Accoustica spin it again, which has eradicated the unwanted buzz. i did this by running the AUDIO TRACK thorugh it saving it with the same filename. Then i swap the noisy audio track for the cleaned track. AND HERE IS THE PROBLEM, when the MPEG video file is played there is NO audio track. Wether using DVD AUTHOR or in WMP. Surely if the cleaned audio file has the same name as the original dirty file. all should be ok.............whats gone wrong![]()
To add to the above i have tried MULTIPLEXING the video and the clean audio, then putting the output into DVD AUTHOR, but it wont accept the audio
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
Dilema ? Problem when converting video with audio track
By doward in forum ffmpegX general discussionReplies: 5Last Post: 1st Dec 2010, 13:32 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
Vdub audio filters causing problem on video track
By SearchQuality in forum AudioReplies: 4Last Post: 10th Feb 2008, 11:42 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
