tried diff media,cleaning thanks for any help,I aoppreciate it
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 11/21/2005 12:48:20 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 1:18:04 PM
Nero version: 6.3.0.2 (Nero Express)
Recorder: <Memorex DVD+/-RW True-8X>Version: 1.19 - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <Memorex DVD+/-RW True-8X>Version: 1.19 - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : MAXTOR 6L040J2 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : Memorex DVD+/-RW True-8X atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD-ROM DDU1621 atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
Memorex DVD+/-RW True-8X D: CDRom0
SONY DVD-ROM DDU1621 E: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 255MB (261132kB)
Free physical memory: 51MB (53192kB)
Memory in use : 79 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
9.2.2008
UDF/ISO compilation
3:09:39 PM #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
3:09:39 PM #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
3:09:39 PM #3 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
3:09:39 PM #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
3:09:40 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
3:09:40 PM #6 Text 0 File Writer.cpp, Line 124
Writer Memorex DVD+/-RW True-8X running
3:09:40 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
3:09:40 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3882
3:09:40 PM #9 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
3:09:41 PM #10 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1316863 (292:38.13, 2571MB)
3:09:41 PM #11 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
3:09:41 PM #12 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: Memorex DVD+/-RW True-8X, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
3:09:41 PM #13 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
3:09:41 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 1316864 (1316864) = #1316864/292:38.14
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1316864 blocks [Memorex DVD+/-RW True-8X]
3:09:41 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [Memorex DVD+/-RW True-8X] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 2696937472, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1316864 | lead-out | 1 | 0x00 | 0x41
3:09:41 PM #16 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
3:09:42 PM #17 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
3:09:42 PM #18 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
3:09:42 PM #19 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 2x (2,760 KB/s)
3:09:42 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
3:09:42 PM #21 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 8:20,364 (500364ms) -> OK
3:09:42 PM #22 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
3:09:42 PM #23 Text 0 File Mmc.cpp, Line 19451
Set BUFE: supported -> ON
3:09:42 PM #24 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
3:09:42 PM #25 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
60 00 10 20 30 40 50 00 - 00 00 21 00 00 00 00 00 `...0@P...!.....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
3:09:43 PM #26 Text 0 File Cdrdrv.cpp, Line 1277
15:09:43.968 - Memorex DVD+/-RW True-8X\H1 T0 : Queue again later
3:09:56 PM #27 SCSI -1061 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03940000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0xD9
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x04 0x00 0x0B 0xD2 0x23 0x0E
0x00 0x00 0x00 0x00 0x44 0xD9
3:09:56 PM #28 CDR -1061 File Writer.cpp, Line 301
Internal target failure
3:09:56 PM #29 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
3:09:56 PM #30 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
3:09:56 PM #31 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 767
3:09:56 PM #32 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
3:09:56 PM #33 Text 0 File dlgbrnst.cpp, Line 1658
3:09:56 PM #34 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 2x (2,760 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 11/21/2005 12:48:20 AM
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 12/5/2005 12:12:26 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 12:59:42 AM (Adapter driver for rea new one
Results 1 to 9 of 9
Memorex are a very mixed bag. Personally I wouldn't touch them.
What errors does Imgburn produce ?
DVD Shrink doesn't burn. It uses Nero or DVD Decrypter. Which do you use ?Read my blog here.
didn't know that about dvd shrink, not paying attention.not sure of that error.I burned the iso in img burn now that I think about.I didn't save the failed log in img burn just nero.I think the memorex is not too good also.it will not burn most kinds of media these days,pretty much just the sony.also it will fail to burn at higher speeds I have to stay at 2x.If there was a fix I'd try it but my thinking is just break down and buy a new one
thanks for the input -
jfrenchu,
The atapi error code returned is vendor specific, so which part of the drive is-failing/did-fail is unknown, but it doesn't really matter which part it is. Some part of the burner is either going bad, or has gone bad.
My advice would be to follow guns1inger's advice...get a nice new shiny drive. -
Drive appears to be Memorex, media in log is SONY.
Why are you burning at 2x? 16x media doesn't burn well at 2x in many drives. -
How old is your DVD burner? A lot of burners give out after a year or two. And like the other guy said, a new burner is cheap and relatively easy to install yourself or to have a friend put in.
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 01:57 -
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
Software fails to recognize DVD-RW discs
By Mummyscurse in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Oct 2008, 16:07 -
DVD authoring fails - 'error in parsing XML'.
By Levina in forum ffmpegX general discussionReplies: 12Last Post: 22nd Mar 2008, 09:10
