I've got a DVD which had wrong subtitles. I created correct subtitles in Subtitle Workshop and converted them to .sup format and added them to the DVD as described on this guide. (When remuxing, I only selected the new subtitle, and didn't include the old one).
My problem is, subtitle's background is not transparent. I tried both IfoEdit and ReJig, but with both of them, subtitles (which are white text with black borders) have a white background. How can I fix that?
You can try dvdsubedit to edit the colors.
Or try this method https://forum.videohelp.com/topic338721.html to add subtitles. -
I convert the subtitles from .srt to .sup using SubtitleCreator. It shows the background and the text correctly (green background, white text).
I tried DVDSubEdit on the final output. It shows that the text is in white, the "b" color (for background) is in green, but to my surprise, there is a "white" box behind the subtitle (that is, "p" is used both inside the text and outside the text, and "b" is not used at all!)
How can I fix this? -
Never mind! I fixed it
I think the IFO file of the original DVD was corrupt. I needed to reference to it when using SubtitleCreator, and it didn't tell me the IFO is bugous. Then I downloaded Txt2Sup and it told me the IFO is bugous. It also instructed me about how to fix its bugs with IfoEdit. Now the DVD is fine
Question about subtitle background
By hamham1991 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2011, 04:06 -
DVD logo with a transparent background
By cobra jet in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 15:31 -
Chroma-Keyed Video with Transparent Background on a Website
By ambassador in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2008, 21:50 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
I want to create transparent background videos for website
By cctaco in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2007, 16:30
