Hi everyone. Newbie here. LOL.![]()
Im trying to use Autogk for basic encoding from a Xvid to a AVI Divx file. This way i'll be able to burn a few movies on a DVDR and watch them on my DVD player.
I'd like to know what settings I should be using if I only want to fit lets say 2 movies on a DVD blank disc.
I'd like good video and audio, and also want to have the files written in DivX.
After waiting almost 2 hours to convert 1 AVI Xvid file to a DivX file, Autogk started "running second pass" and it now opened Virtual Dub and started at 1% again. It is VERY slow. Are there any settings I missed? All this time I simple could've used DivX converter and then burned the file to a complete DVD with chapters.
Is AutoGK really this slow? 2 hours, and now another 2 hours to convert it again? Am I doing something wrong? Please, any help or what basics I need to do, would be VERY APPRECIATED!!!!!!!!!!![]()
Nothing wrong. 2 hours/pass sounds about right for a single kernel 2.7 GHz box, if you're talking about the average movie.
You can tell AutoGK to just use single pass, but that'd give you a lower over all quality at the same file size.
You can also use the quantizer mode, which will give you a known quality (that you set) but undetermined file size. However, for 2 movies to 1 DVd-5, you can usually crank the quantizer up (low, in fact, as lower quantizer=higher quality) very much.
But why reencode from XviD to DivX? 99% of all players that can play DivX can also play XviD. Lots of guides for AutoGK if you look it up under Tools left.
/Mats -
Thanks Mats. Well consider my dumb. LOL. I didnt realize the DVD player could play Xvids as well. I thought they had to be written in Divx codec. Guess it depends on the DVD player. I will check my player and see if it does. Duh!!
Also if I indeed do want to convert to DivX - can you explain that part above where you mention crank the quantizer up etc? Also when selecting the type of output, should I select 1 cd or 2 cd or 1/3 or?? My preference is to have the exact quality as the AVI im starting with on my computer, no matter the output size. -
http://www.doom9.org/index.html?/autogk.htm , especially step 3 answers your questions.
And:isn't possible, as every reencoding takes some quality away.to have the exact quality as the AVI im starting with on my computer, no matter the output size
/Mats
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
autogk
By maxone71 in forum Video ConversionReplies: 4Last Post: 13th Mar 2011, 21:27 -
Best Settings for Autogk
By skorpinok in forum Video ConversionReplies: 0Last Post: 21st Nov 2010, 09:13 -
Help with AutoGK please
By smackyourfupa in forum DVD RippingReplies: 7Last Post: 29th Nov 2007, 03:21 -
AutoGK Settings: Frame Rate Confusion
By Tom Saurus in forum Video ConversionReplies: 3Last Post: 30th Sep 2007, 06:18
