One of my all time favourite movies. How do I convert it to hdtv x264?
I'm a new registrant.![]()
Ok what is your source? Is it a hddvd/bluray disc? Is it a high def capture? We need more detail.
Also this will give you more detail as well:
https://www.videohelp.com/convert
Welcome to the website
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
In that case you don't need to any upconverting to hdtv, it is simply not worth it and will ruin your original source.
Use a converter like super found in the tools sections on the left of the screen:
https://www.videohelp.com/tools
Do not use a codec pack! That is bad. Just use whatever variant of 264 you want. Since you are in ntsc land you will use 720x480 as your resolution since that is what dvd spec is for ntsc.
You might want to use divx/xvid instead of 264. It is probably more suitable for whatever your final destination is (ie portable video player or settop divx compatible dvd player). However if you intend to just watch it on the computer than any form will do.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Small image:
Made big:
Quality doesn't increase. Not like starting with an even higher resolution source and making the same size:
Cowboys and Aliens Rental Disk Blue Ray
By wulf109 in forum Blu-ray RippingReplies: 22Last Post: 5th Jan 2012, 22:24 -
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
have aliens visited earth?
By deadrats in forum Off topicReplies: 3Last Post: 14th Oct 2010, 22:14 -
Aliens Vs Predator 3 FPS PC Game?
By retroborg in forum Off topicReplies: 0Last Post: 28th Jan 2008, 08:34
