How can I check to see if a DVD is 480p or 480i?
That is to say, what is the easiest way to check?
While we're on this topic, are the Region 1 DVDs in the Season 1 Box Set for Jericho 480p?
Oh, and if not, is there any word on when they'll be released (if ever) on BluRay or HD-DVD?
I'm debating on wether or not I should go ahead and buy the DVDs, or if I should wait for a HD-DVD or Bluray release.
I've spent a couple of hours googling about what's written in this post, without much luck.
I even tried looking for an online List or Database that says witch DVDs are 480p and witch are 480i, but I didn't find any.
g-spot. If the pics per second is 23.976 and the fps is 29.970 then you have 480p with pulldown. If the pics and frames per second are both 29.970 then you have interlaced. That's about as close as you get without actually going through the video frame by frame. It's not 100% accurate, and doesn't work for PAL video. But it's close enough most of the time.
All of this is moot if your player doesn't support progressive output and your TV can't play progressive output.Read my blog here.
How to transcode HD .MKV file to watch on standalone 480p DVD Player?
By prankstare in forum EditingReplies: 4Last Post: 26th Mar 2012, 17:39 -
Converting 720p to 480p (maybe even 480i) Need how-to procedure
By TheNomad63 in forum Newbie / General discussionsReplies: 1Last Post: 7th Dec 2010, 01:43 -
1080/60i to 720p (for AVCHD Disk) and 480i (For DVD)
By greymalkin in forum Video ConversionReplies: 87Last Post: 25th Jun 2010, 06:06 -
shooting in 720p, will downconvert to 480i for dvd
By apollo1980 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2010, 12:33 -
480i/480p in DVcam vs. conversion
By celticwhisper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 19th Jun 2007, 11:54
