My computer came with some DVD editing/authoring software.
A few days ago, I recorded THE DAY THE EARTH STOOD STILL off AMC to a DVD using a stand-alone.
I then used that disc to drag'n'drop the movie into the computer, and took out all the commercials.
Worked fine. NICE results.
Tonight I tried to do the same thing with a disc recorded off of the FX channel's recent showing of FEVER PITCH.
I have a DVD recorded with all the commercials, and dragged the files off onto the hard drive.
When I tried to use one of the files in the editing/authoring software, it wouldn't let me. Kept getting a message that says "Failed to add video file."
I tried it again with another video file I have on the hard drive, and it came over fine.
Could FX have put some sort of copyguard on FEVER PITCH that AMC didn't put on THE DAY THE EARTH STOOD STILL?
The latter was easy to edit. With Fever Pitch, I can't even get it into the program.
I'm still new to this stuff, so go easy on me...
Possibly a scratch on your disc causing errors.
Donadagohvi (Cherokee for "Until we meet again") -
gastrof: I recommend Womble Mpeg Video Wizard for cutting out commercials and such. A wise thing to do as well when you are recording tv shows and movies is to go to the search page at imdb and look up the movie you are recording. I have found that AMC will edit out portions of a movie to make it fit in the time alotted. So you may not actually have the entire "The Day The Earth Stood Still". At IMDB you can find out the running time of the movie among other details and this can be very useful to those who record shows and edit them to archive to watch at some later time.
I'm using POWER PRODUCER 3. Don't know exactly which "sub-version" (if any), since it came pre-installed.
Now, tho', it gets weirder. The first three files making up the movie "took" just fine. It was only the 4th file (with the final half hour or so) that the software wouldn't take.
My stand alone recorder is the Philips DVDR3455H. The only thing I can figure is that when I removed the "other bits" that followed the movie (using the Philips own editing feature) before creating the disc, I somehow damaged the file?
The movie still plays fine on the hard drive and on any discs the machine creates, but I can't get that segment to be accepted by Power Producer.
I also tried sending it to Nero, and Nero also insists something's wrong with that segment.
Can this happen, where the file gets damaged and can't be used by editing software, but otherwise will still play fine?
Editing .TSV recordings
By kyrcy in forum EditingReplies: 10Last Post: 11th Dec 2024, 03:38 -
LiteOn Recordings Compatibility Question
By jeanpave in forum DVD & Blu-ray RecordersReplies: 19Last Post: 25th Nov 2008, 19:01 -
editing question
By Noobmeister in forum Newbie / General discussionsReplies: 12Last Post: 1st May 2008, 18:19 -
???? Question About Film Editing
By shellelyn in forum AudioReplies: 4Last Post: 3rd Mar 2008, 17:50 -
Question on editing vc-1 file
By ultraman36 in forum EditingReplies: 2Last Post: 13th Dec 2007, 07:34
