I'm using the lastest version of DVD fab and am trying to convert a movie to xvid at 5000kbps and dvdfab will never out put it out at that even though i have picked "fixed bitrate"
Any ideas?
Hi-
I assume it's finishing somewhat below 5000? If so, you've saturated the codec. 5000 is a pretty high bitrate. You've already achieved the best possible encode given your settings, and the AVI can't use any more of the bits. Doesn't it look pretty good already? The only way to achieve a greater filesize/bitrate would be to change your settings. Use a higher resolution, for example.Any ideas?
I've never encoded an AVI using DVD Fab (and never intend to), so I can't be more specific than that. Also, Fixed BitRate (CBR encoding) is an inferior method to use. Use Fixed Quality (if it has that or something similar) or 2-pass Variable BitRate (VBR) encoding for better results. -
when set to 5000 what i get varies sometimes 2900kbps but usally below. They will be played on my PC so 5000 isnt to much.
Eeven using a high rate the dvd is half the size.
I've used DVDFab in the past and got the bitrate up to 5000 so i know it can do it. I don't know what version it was though. -
of course it will, have you tried on a SAP?Originally Posted by David97
I wonder why! with such a hight bitrateOriginally Posted by David97
i never used more than 1500 when converting to xvid/divx....5000 is waaaaaay too much....try autogk or avi.net and set 1500 as bitrate and keeping ac3 aswell.....Originally Posted by David97I love it when a plan comes together! -
I need 5000kbps, i need it on a 60" screen. I stream the movies from my PC to a PS3 to a 60" HD TV and i can see a differance in 1500 and 5000.Originally Posted by ricardouk
Dvdfab will do 3000kbps and i can get it to do 5000 when doing a small clip from the movie which makes no sense to me.
outputing AVI at 1280x720p in Premiere Elements 9 help please
By ronh_pm in forum EditingReplies: 5Last Post: 2nd Jan 2010, 00:26 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 09:32 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
Outputing HDV
By smith19 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 09:16 -
Outputing the audio from PowerDVD thru S/PDIF
By maxpower2078 in forum Software PlayingReplies: 3Last Post: 4th Dec 2007, 10:36
