I downloaded a movie from a torrent site, the damn thing stopped at 99.9% (4MB left)
and itīs been trying to complete for over four days without success.
If it was a .VOB file I could burn it onto a disc just the same with none or little video problems.
The thing is itīs divided in 95 .rar files and if I try to extract them I get a
"bad block/crc error" because of the uncomplete file.
Is there a way to fix the file so I could extract it partially?
Thanks in advance.
Closed Thread
Results 1 to 14 of 14
either find par files to repair it or maybe the creator was kind enough to include recovery overhead in the rars. try highlighting the bad rar and clicking repair in the winrar menu. treat as rar. good luck as not many people use this nice feature.
p.s. you can extract the archive with the error if it doesn't work by checking "save broken files" in the menu.--
Dear friends,
I managed to solve the problem by following your instructions, installing WinRAR and ticking the box Keep broken files. Experienced minimal choppy playback here and there due to the missing 4MB but nothing that could ruin the video.
Thanks a lot for your help guys.
There are a bunch of apps that might fix that:Originally Posted by dexter30
https://www.videohelp.com/tools/sections/video-repair-fix
Wow, another posthunter teetering on the brink of breaking the rules, trolling obnoxiously on a forum called videohelp. Hmmm...Originally Posted by hech54
Now back to the topic...
You are probably out of luck, dexter30; although you failed to disclose any more facts about the file inside the archive (how large is it?), it seems that nothing will help help you - only getting the missing parts.
Recovery blocks, though frequently present in archives, will probably not help you. Even though the recovery blocks can be as large 2^19 "sectors" (=2^9 B; i.e. 256 MiB in total), the options normally used are expressed in % ot the size. And while it can be specified on the command line, the Windows GUI version only allows setting it up to 10 %. Given the size of (unknown to me) the RAR chunks (volume) and the size of the torrent chunks (at least 32 KiB), the recovery record should be at least as large as the missing (damaged) part in order for the recovery of that volume to be theoretically possible.
But if you encounter an irrepairable volume somewhere "in the middle of" an archived file, then the rest of the file will be unrecoverable.
The solution is either to look for possible REV (RAR recovery volumes, which can replace entire RAR archive volumes), or, as suggested above, PAR (parity volume set archive) files. Both are similar in their function, both are probably similar in availability - which I estimate as very poor.
Nevertheless, you can search for the same torrent elsewhere, or contact the uploader. Otherwise... you are stuck.Pierre-Joseph Proudhon: "Property is theft!"
PowerDirector: Extract single scenes from Movie --> HUGE(!) file
By Katzwinkel in forum EditingReplies: 1Last Post: 5th Nov 2010, 17:46 -
I can't rip a complete movie.
By Marccc in forum DVD RippingReplies: 1Last Post: 17th May 2010, 07:39 -
How to Convert RAR HTML Files Into A Movie File
By raven120461 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 12:35 -
opening one rar file
By tweedledee in forum Off topicReplies: 2Last Post: 18th Aug 2007, 14:16 -
AVI to DVD - not complete movie!
By stuie_e in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2007, 14:52
