I have been using ConvertXToDVD for years and know the programs like the back of my hand. Recently something very strange has been happening when I am converting my file. The program will convert some, more or less 50 percent then restart my PC. what is going on here?
Can anybody help me?
The same happens when I use Magic Video Converter, doing fine until it just restarts out of the blue.
I can rip and burn full official DVD's. Menus, Special Features and all. Also can burn CD's and data DVD's as well.
What is going on here? I love ConvertX and miss using it.
Please help me, wise Burning Wizards.![]()
I dont know if its program issue or heat. Converting makes alot of things overheat and shutdown.Try cleaning the fans and the inside of comp.W/compressed air.And on the software side of things, Have you resently updated this program?
People who love sausage and respect the law should never watch either of them being made. -
sounds suspiciously like an overheating cpu problem. check your temps while the cpu is running 100% for awhile. either boot the comp into bios screens or get a program like this to monitor with - http://www.alcpu.com/CoreTemp/
I will try the heat issue, thank you. My fans and internals are all clean, I just bought a nice Antec case.
No I have not updated it, I am using version 2.23 if that helps any of you guys.
And thanks once again. It really sucks not being able to use the program, I know it has a lot of love around here. And rightfully so.
Is there a way on how to shutdown xvid4psp after encoding?
By mark63534 in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2011, 00:05 -
Laptop shutdown problem
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2011, 13:27 -
Handbrake shutdown switch
By leghorn in forum Video ConversionReplies: 1Last Post: 16th Mar 2010, 08:54 -
ConvertX2DVD shutdown
By smalld in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 21:27 -
Automatic Shutdown
By borisblavasky in forum ComputerReplies: 10Last Post: 12th Jun 2007, 15:13
