OK i was trying burn games for my 360 and i bought prime dl disc and everytime i burn one i get unplayable disc or unreadable disc and its pissing me off so
00000000 08 02 00 00 01 0F 31 10 00 03 00 00 00 FB 04 DF ......1.........
00000010 00 20 33 9F 00 00 00 52 49 43 4F 48 4A 50 4E 44 . 3....RICOHJPND
00000020 30 30 01 40 25 25 37 11 00 34 64 00 34 64 20 21 00.@%%7..4d.4d !
00000030 0C 0D 12 12 02 01 01 10 00 20 21 0C 0D 12 12 02 ......... !.....
thats the media code what should i do to burn properly and btw i got a pioneer dvr 108 with firmware 1.20
if anyone has ideas tell me or if it wont burn with pioneer can you tell me if it would work with anyotha burner i heard the sony nec burners work well with it
HERE GO MORE INFO
Disc Regions are 1,2,3,4,5,6,7,8
CSS Protected No
Media code/Manufacturer ID RICOHJPND0
UDF Format Type V1.02
UDF Volume XGD2DVD_NTSC
UDF Application id
UDF Implementation id Sonic Scenarist 3.1
UDF Recording Date/Time (mm/dd/yyyy) 03/06/2006 21:09:07
Format Capacity 7.05GB(7.57GB)
Book Type DVD-ROM
Media Type DVD+R DL
Data area starting sector 30000h
Data area end sector 386C1Fh
Layer 0 end sector 20339Fh
Linear Density 0.293um/bit
Track Density 0.74um/track
Number of Layers 2
Layer Track Path direction (OTP) Opposite track path
Complete Media Code
11 Programmes used - still can't join mp4 successfully?
By The.King in forum EditingReplies: 20Last Post: 13th Oct 2012, 03:32 -
Can't get multiAVCHD to successfully create an AVCHD folder???
By jwmghf in forum Authoring (Blu-ray)Replies: 15Last Post: 17th Nov 2011, 13:37 -
Prime Image Freeze II question
By pgoelz in forum Capturing and VCRReplies: 9Last Post: 12th May 2011, 18:39 -
Have you successfully backed up the Casino Royale?
By coody in forum DVD RippingReplies: 122Last Post: 27th Sep 2010, 03:21 -
Did the original optimus prime voice actor do the recent Coors commercial?
By yoda313 in forum Off topicReplies: 5Last Post: 14th May 2009, 15:00
