Hi, here's what I want to do:
Lower the current sound of the video (so it is present but not that loud)
Then
Overlay an mp3 that corresponds to the video, and line it with the video.
Any ideas? I have virtualdub if that helps.
You could use the freeware audio editor Audacity. Extract the audio from the file with VD, drop it into Audacity, along with the music, blend or mix as wanted, then output as MP3 and add back with the original video, disabling the old audio, then save the audio and video out as direct stream copies.
Audacity accepts MP3, WAV, AIFF and Ogg audio streams. If the video has MP3 VBR audio, I would save it out as a WAV with full processing in VD, or you may have sync problems. I use VD Mod for all that most times, as I prefer it's audio handling. But the regular VD will work also.
And welcome to our forums.
Not sure about Virtualdub 1.7.7 but the experimental version which is now 1.8.0-test8...
http://www.virtualdub.org/beta/VirtualDub-1.8.0-test8.zip
...will handle VBR MP3 audio. -
I can use Audacity to do it, but I need help.
The song I want to insert, and the current audio track both start at the same time when I import the mp3. I want the song to start playing after xx
x in the current audio. How do I move it around in audacity? Every time I cut and paste it, it just goes back to the beginning.
Use the 'Silence Generator' in 'Generate' to create a length of audio silence, then paste it into your track to offset the track.
Audacity docs, tutorials:Originally Posted by Kingnautilus
http://audacity.sourceforge.net/help/documentation
http://audacityteam.org/wiki/index.php?title=Audacity_Wiki_Home_Page
I recommend the "Beta 1.3.4", it has several improved features over the "Stable 1.2.6" version.
Anyway, specifically you want to use the "time shift tool", the double-headed arrow button.
You can grab a track and slide it along the timeline
Also, when I'm mixing commentary tracks I use the "Compressor" effect to knock down the peak volume of the original soundtrack.
I use a ratio of 10:1, Threshold about -28, and turn OFF normalize; experiment to find your optimal setting.
Creating MP3 audio files from MP4 videos
By Kiwi999 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2011, 05:16 -
question. FAAC or MP3 lame for videos
By llmercll in forum Video ConversionReplies: 4Last Post: 1st Feb 2009, 23:05 -
can you id tag videos like mp3's?
By lordhutt in forum ComputerReplies: 3Last Post: 12th Jan 2009, 19:47 -
where to obtain overlay videos with alpha layer
By perfection in forum EditingReplies: 1Last Post: 13th Nov 2008, 00:41 -
mpg with a good MP3 sound in music videos
By copiche in forum AudioReplies: 5Last Post: 24th Aug 2007, 13:22
