    Feb 2008
    Cyprus
    i have the clone dvd2 end the last dvd it did`nt make it coz of rigion codet is the first time that i have this proplem
    did i make somthing wrong
    thanks
    USA
    Region codes shouldn't matter if you are backing up a DVD, it would remove them. That sounds more like a PAL/NTSC problem. Or a ripping problem, if the video is using a newer form of encryption.
    I use the freeware DVDFab HD Decrypter>DVD Shrink>Imgburn.
    Aug 2002
    South Florida
    CloneDVD2 is designed to be used with AnyDVD. That's a good combo! You need both.
