    Feb 2008
    I know this sounds like a stupid question but I can't figure it out. I have a DVD that was recorded on a DV camcorder. I also have another piece of video and want to combine them on a DVD. I have done this many times but this piece of video is formatted at 352x480 and I can't convert it to 720x480 to add it to the other. When I burn it the standard video is fine, but the 352x480 video is tall and skinny. I put the video in Adobe Premiere and tried to change the aspect ratio to D1/DV NTSC (.9) but it is still 352x480. I generally use ShowBiz to put projects together, but it does not allow me to change format size. I also have Windows Movie Maker. Can anyone give me step by step instructions with any of these programs? Would be greatly appreciated. Thanks!
    Oct 2005
    666th portal
    i don't use premiere but with most encoders there is a check box for full screen. if it's checked and 720x480 is selected for the output it should encode it that way.
    Feb 2008
    One would think it should be that easy. I have tried clicking on the correct size, but it doesn't change anything.
  4. Member classfour's Avatar
    The Heartland, United States
    Have you tried TDA
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Feb 2008
    Went a different direction and got it done. I went from a DVD player with s-video to a camcorder and then firewired it into my computer and captured it with Windows Media Player. I then saved the project as an avi file which dropped right into ShowBiz with no problem. Thanks
