    Feb 2008
    Hong Kong
    First post. Feel free to hammer me but I have searched and cannot find an answer to this.
    I am encoding files in Windows Media Encoder. I would like to verify that the output files are free of glitches or errors. I know I can do this by actually watching each movie, but I would like to save the time and find a more robust method of checking these encoded WMV files.
    Any idea how I could go about doing that?
    Oct 2005
    666th portal
    welcome to the forum! maybe the easiest way would be to use gspot. open gspot and drag your file to it. it will read it and give you the results.
    Feb 2008
    Hong Kong
    Hi and thanks for the reply!
    I have GSPOT, and maybe Im not as adept with it as I should be, but I thought it only gave you the properties of the file; how it was encoded, what settings, etc.
    What I am after is a way to spot any glitches, any problems, lack of audio, video skipping, that sort of thing.
    Oct 2005
    666th portal
    if gspot doesn't complain after examining the entire file it and it lists an audio and a video track it is most likely just dandy. it would stop at any errors it encountered.
    Feb 2008
    Hong Kong
    ok great, thanks!
  6. Member bendixG15's Avatar
    Aug 2004
    I use Nero 6 to test my DVDs (thats about all I use it for these days.)
    Will test the entire DVD and it does tell you if the DVD is not readable.
    (I had 3 bad burns on Verbatim disks and Nero caught the them)
    Apr 2004
    Miskatonic U
    All you can test for is of the streams are clean. You cannot test for visual or aural glitches in the encoded video. It is quite possible to get a good encode (clean stream) with glitches, but there is no way to automagically check for it.
    Read my blog here.
