What kind of tools can be used to sync up an avi with AC3 sound, or at least mp3 sound?
In what way ?
In what type of container ?
If the audio is out by a constant amount then all that is needed is a simple delay adjustment. DelayCut can do this, as can many authoring tools and virtualdub.
If the audio drifts out over time, perhaps because of a poor format conversion, it becomes a bit more complex. Audacity or BeSweet can be used, depending on the file and the need.
However to be more specific requires a lot more information from youRead my blog here.
what if the sound is slower than (trailing behind) the video and is in an mkv?
Use MKVExtract (with mkvtoolnix in the same folder) to extract the audio and video streams.
Using Media Player Classic : File -> Open, open the video stream using the Open field, and the audio stream using the Dub field. Play the pair (don't scrub, just play), and use the + and - keys on the numpad to work out the delay.
Once you have the delay, use DelayCut to change the delay on the AC3 file.
Finally, use mkvMerge GUI to create a new mkv file with the audio and video no in sync.Read my blog here.
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Dark City Project-Edit AC3 soundtrack
By apostrophe in forum EditingReplies: 8Last Post: 23rd Apr 2010, 23:06 -
Lipsync problem with finished DVD
By Ewen in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 16:50 -
mkv -> m4v with AC3 soundtrack problem
By jamesmac in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2008, 16:54 -
re-encode lipsync
By marcopolo1 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Mar 2008, 16:48
