  1. Member ribac's Avatar
    Czech republic
    Hello ,
    I need some help.
    When I had Windows XP I used to have video codec "Codec Pack all-in-1" which was good.
    Now after buying of new computer video plays only sound.
    does anyone experienced problem with videio codec on Vista or do you know any pack which I can use??
    Thank you
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, none. Codec packs break more than they make.
    If something plays without audio or video, use GSpot to determine what codecs is used. Install the codec your missing. Done.
    Install ffdshow (not a codec pack, but a very versatile codec) and you're well covered a.f.a. playback goes.
    /Mats
