You can use Enosoft DV Processor to convert raw DV to DV AVI.
I don't know if it's the source of your problem, but Quicktime Player really sucks under Windows.
Results 31 to 32 of 32
dbx,
If you choose the PC route with our software, here is a configuration file for it that will make the process easier:
video8correction.dvpconfig
Open the software and drag this file onto it or use the software's Load... button.
This will configure the software to adjust the brightness and color.
All you need to do is select one of your captured .dv files as input, choose a name for Raw DV File... output (or AVI if you need it) then click the Run button.
What is best way to improve soft SD channel detail on LCD TV ?
By DBenz in forum DVB / IPTVReplies: 8Last Post: 28th Mar 2011, 11:23 -
improving dark skin detail
By BobAchgill in forum RestorationReplies: 14Last Post: 1st Jan 2009, 04:31 -
enhancing detail from video for a customer in trouble
By devdev in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2008, 15:29 -
MPEG document describing 'open GOP' in detail?
By Alex_ander in forum Video ConversionReplies: 7Last Post: 9th Jun 2008, 13:49 -
Enhancing video detail/quality
By azinkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jun 2007, 08:16
