I have an mkv video file with 2 audio tracks, French and English. When I play the mkv file with Media Player Classic, the French audio track is played by default (I can select the English track). When I use DVD Flick, version 1.2.1.3 build 348 (to convert mkv file into DVD), the 2 audio tracks are automatically loaded, but the resulting DVD has French as the default language. My question is: Is there some way in the DVD Flick settings to make English as the default language? Every time I play the DVD on a standalone, I have to select the English audio track, otherwise the French audio track will play.
Thank you, I downloaded PGCEdit, and also the guide at: http://forum.digital-digest.com/showpost.php?p=296707&postcount=1
and after studying the simple guide was able to make English as the default language in just a minute.
Couldn't have done it without the guide, as PGCEdit does a lot of things and appears complicated.
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Strange audio shift when using other audio track than default
By Heliooos in forum DVD RippingReplies: 2Last Post: 25th Mar 2010, 00:46 -
DVD Flick - 'cannot load audio track 2....has more than 2 channels'
By silver007 in forum Video ConversionReplies: 0Last Post: 14th Aug 2009, 20:55 -
How to change default movie track?
By thomasbbb in forum MacReplies: 1Last Post: 6th Aug 2008, 14:36 -
Change audio track automatically on DVD
By kremlincrackers in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2008, 06:24
