What is a Low-Motion Divx is?
is it some kind of Divx version or something?
what does the words "Low-Motion" refers to?
the video maybe?
any help would be much appreciated.
TIA.
It's probably old DIV3 encoded video. It is DivX, just old. The low-motion refers to the low motion version of the codec. DIV3 was used for low motion (better for low motion parts of video, but suffered in high motion sequences) and DIV4 was used for high motion (but low motion sequences suffered).
theHTPC.net
Find a cure for cancer by folding proteins! Join the Team 32 Folding@Home project (#3 worldwide!). Check us out here -
Many players don't support the older versions of Divx. Try it on your drive and find out if it works. But I don't see any reason not to use the latest version of Divx if you're making new files.
jagabo, no, i'm not making a new files...
i guess i have to try and play it...
to see how it runs.
thanks for you help.
Processing of DIV3 Low Motion
By davexnet in forum Video ConversionReplies: 4Last Post: 2nd Apr 2009, 05:41 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
Hypercam, Low Motion & Youtube
By DaMasteRZ in forum Video ConversionReplies: 3Last Post: 12th Aug 2008, 14:11 -
Compression performance achievable with low-motion scene?
By Volatris in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2008, 07:56 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 18:42
