I am having a problem playing DVDs in WMP 10 and 11 and Real player. The video plays great in each of them, but there is no audio. However when I play a DVD in VLC, Media Player Classic, and Nero Showtime it plays fine with audio. I have not downloaded any codec packages or anything like that. I just have what came with each of the programs. I have used Gspot and the Windows XP Video Decoder Checkup utility. Gspot told me I had the proper codec to play it and the decoder utility told me I had the proper decoder. Any ideas????
You might try installing AC3 Filter, though I don't know if RealPlayer will use it.
If cameras add ten pounds, why would people want to eat them? -
The decoder is Cyberlink Video/ SP deceoder, Decoder File Name:CLVSD.ax Version: 6.0.0.1006
I have checked the advanced settings and they are set at 2 speakers and I switched back and forth on the other setting to no avail.
I already have the AC3 filter -
JMO, but WMP is not a good player. Even in the latest versions. It has to 'phone' MS before it can play much of anything.
If VLC plays it, what's wrong with VLC? RealPlayer also seems to be a resource hog and 'phones' Real at every chance.
I would use Real Alternative Player instead if you need to play Real videos. (It uses Media Player Classic.)
WMP can be difficult at times to configure, probably because it's a bit too closely tied to the OS and shares it's 'Protections'. Gspot told you that you have the proper audio codec. Which one? The AC3 Filter may not be agreeable with WMP or it has problems. I would un-install and re-install it.
I don't really mean to be negative about WMP or Real, but they don't seem to work that well. Again, JMO.
You could also try un-installing and re-installing the Cyberlink program, in case it got damaged at some point.
DVD Player and WMP don't play DVD Subtitles. PowerDVD shows it in black
By GoNGaXiNHuO in forum SubtitleReplies: 5Last Post: 17th Jul 2011, 01:14 -
How to convert and burn a quality DVD from Real Player (.flv) download
By elaway in forum Video Streaming DownloadingReplies: 1Last Post: 17th Jan 2010, 18:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05 -
WMP/REAL Player - Some of my old videos as well as new are playing weird?
By Akabane Kurodo in forum Media Center PC / MediaCentersReplies: 2Last Post: 5th Jul 2007, 15:12 -
How to find the real codec - VLC plays but WMP wont
By oglasifwd in forum Software PlayingReplies: 1Last Post: 5th May 2007, 20:20
