I found it, Hold Control and stretch the clip.
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
Yeah how do you do that? For instance I'm editing a surf video, and there was a part where he does a kick back I wanted to slow down then regular speed to the next big air trick. I ended up cutting 3-4 clips just so I could slow down those two parts. This would make a huge difference.
Right-click on your video track & add a velocity envelope, as guns1inger advised. The default velocity (100%) is normal speed....set points (@ 100%) before & after the sequence you want to slow down, then add 2 more points "inside" the first 2...drag the inside points down to the desired slo-mo speed. The idea is to have "normal", 100% velocity before & after the slo-mo part. Good luck.
Stiiv -
So you have Vegas Movie Studio 8. OK then, you probably don't get velocity envelopes. I really wish Sony hadn't changed the names.
Read my blog here.
This is Sony's response:
Hello,
Thank you for contacting Sony Creative Software. Velocity envelopes are only a part of the pro version of Vegas Pro 8.
However, we are always open to your input and your suggestions. Please feel free to send a product suggestion request at the following link -- it goes directly to the development team: http://www.sonymediasoftware.com/support/productsuggestion.asp
Sincerely,
Marc S.
Customer Service & Technical Support
Sony Creative Software Inc
1617 Sherman Ave
Madison, WI USA 53704
www.sonycreativesoftware.com
www.acidplanet.comHV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850
How can I get the smoothest slow motion out of a clip?
By 123erik in forum EditingReplies: 15Last Post: 14th Jun 2011, 16:15 -
Slow Motion Disable Resample Sony Vegas Pro 10
By bilalarabaci in forum EditingReplies: 1Last Post: 2nd Jan 2011, 14:55 -
Sony Vegas: Any way to undo clip speed adjustment?
By duderdude2 in forum EditingReplies: 2Last Post: 15th Feb 2010, 22:03 -
Slow motion problem in Sony Vegas 9
By plisb in forum EditingReplies: 4Last Post: 16th Dec 2009, 09:32 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 12:14
