Can I edit some of these options out?
I'd like to remove:
CopyToDvd
CopyToDvd Depot
Edit with ImageReady
What We Do In Life, Echoes In Eternity....
1. Click Start
2. Click Run
3. Type in regedit and click ENTER
4. Browse to the following:
HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
5. You simply delete or export then delete the keys you do not want. -
Thanks Baldrick, I tried doing a google but didn't know the name(context menu) of what I was actually trying to search for. Thanks again for the help and pointing me into the right direction
Only DVD_NTSC folder with MPEG2 file inside after converting
By big_b0i in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2011, 08:23 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
How Can I Correct This Collor-Problem? (Sample Inside)
By MrJacobAngle in forum RestorationReplies: 105Last Post: 9th Aug 2010, 11:17 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 08:29
