I bought an Aiptek A-HD camcorder that takes video in H.264 format. I uploaded the videos onto my computer (.mov files) and they play back fine in Apple Quicktime 7.0 (free version upload), however, when I try to import the video files in Adobe Premiere Elements 3.0 it gives me an error - "Unsupported format or damaged file". Premiere elements says is supports .mov file type.........why won't this work? Does it have something to do with the H.264? HELP!!!
It's probably because of the h264. Is adobe premiere elements included with the camera? or does it come with some other editor or nothing?
You could reconvert with quicktime pro or mpeg streamclip but I would try find a editor that support h264 mov directly. -
The camera came with Photo Impression 5, but only does photo editing, not video. I already had Premiere Elements that I purchased seperately last year.
The latest versions appear to support h.264 mov files. You may want to contact adobe to see if there are any updates to whichever version you are using or you may need to upgrade.
Google is your Friend
Premiere Elements 9 or Sony Vegas Movie Studio HD Platinum 10 Suite?
By HoosierGuy in forum EditingReplies: 37Last Post: 26th Feb 2011, 00:55 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 13:21 -
Vegas Movie Studio Platinum Pro Pack vs Adobe Premiere Elements 8
By bowmah in forum EditingReplies: 6Last Post: 27th Jan 2010, 20:15 -
trouble authoring mpg files made in Adobe Premiere Elements 3.0
By compaqted in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2007, 23:14 -
Importing stills into a Premiere Elements movie - how to optimise?
By netwiz in forum EditingReplies: 0Last Post: 2nd Jun 2007, 06:15
