I was able to use TMPEnc DVD Author 3 to convert and burn from an XVID to DVD, but when i played it on a TV, the outcome was that the picture was blurry, almost grainy. Seemed like the pixels were stretched out. What did i do wrong? Please be harsh so that i may learn the right way!
guns1inger speaketh truth. FAVC is a good app. You MUST install Avisynth as well before you use FAVC http://downloads.sourceforge.net/avisynth2/Avisynth_257.exe?use_mirror=dfn
If you find FAVC is beyond your comfort zone, try ConvertXtoDVD http://www.vso-software.fr/download_product_direct.php?product=cx3&ap=avangate&aid=675
Whatever you use, make sure your output is set to 16x9 aspect ratio, since your source file is 624x352.
Newbie needs help with getting burned discs to play on dvd player.
By Takeonelastbreath in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 15:02 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 06:03 -
Blocky or Boxy?
By jethroangel in forum EditingReplies: 2Last Post: 10th Oct 2007, 22:18 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26 -
xvid video I burned onto cd won't play in dvd player
By dvdnewbie64 in forum Newbie / General discussionsReplies: 11Last Post: 5th May 2007, 19:45
