I have a Dell E1705 with Philips SDVD8820 Slim DVD±RW drive which went bust a couple of days ago. Since my laptop is under warranty I called for a replacement and dell sent me a HLDS GSA-T21N 8X DVD�RW, brand new made in Dec2007. However I am worried if the new drive they sent me is better than the old one or worse?
I checked the dell specifications page and got confused. The Hitachi drive is also not there in the Video Help Database so I could not compare it here and read user comments.
Any advice on wether to try to get another Phillips or this one is ok?
Results 1 to 10 of 10
Not looking to buy another, just getting a free one from dell. They have a habit of sending old stuff which is sometimes a downgrade, thats why making sure.
Why would you be worried that the new drive is better than the old one? I'd take better. But I wouldn't settle for worse. You should be able to request the same exact model from Dell so that you don't end up with worse.Originally Posted by tantrik
Dell has no consistancy in peripheral suppliers. They buy whatever is cheapest on the day they buy.
It appears to be the Hitachi version of an LG drive (Hitachi and LG produce drives through a joint venture).
In my opinion it is an excellent drive.
Because you chose to buy a Dell computer you can expect little in the way of firmware updates for your burner. The complexity of having used many different DVDwriters is a lack of support and commitment to support.
Often the reason the replacement drives manufacturers ship differs from the original drive is that the original drive proved to have too many failures. With Dell it is hard to identify such cases due to their purchasing strategy. -
The GSA in the model number is a good sign that firmware may be supported by LG. Most OEM drives from LG that "oldandinthe way" is referring to have model numbers starting with GMA, GCA or GWA. He is correct that those models generally are only supplied firmwares by the computer maker such as Dell, HP etc. This may be a retail drive and an exception to the rule (for Dell anyways).
I haven't seen any firmware for notebook drives on the LG site. I haven't looked at the Hitachi site. The OP seems to indicate Hitachi labeling.
Often the Hitachi version of the drive offers additional features like DVD-RAM, some LG owners cross-flash to Hitachi software when it is available. -
The Firmware page (rpc1.org) has a listing for this drive under LG - laptop - dvd-recorder. Use link below and scroll to near the bottom.
http://forum.rpc1.org/dl_firmware.php?category=14&manufactor=16
It appears to be a Dell OEM drive only so I stand corrected. -
You're probably better off just buying something else for just about any Dell replacement parts. I don't think I'd ever buy a Dell.
Firmwares for Slimtype/Laptop drives have to be provided by the Laptop manufacturer aka OEM.
GSA means LG retail.*** Now that you have read me, do some other things. ***
replacement DVD drive for pioneer 420h/520h
By nrobinson in forum DVD & Blu-ray RecordersReplies: 7Last Post: 11th Jun 2025, 16:12 -
JVC DR-M100 Drive Replacement
By robjv1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Jul 2010, 01:10 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
DVR-220-s drive replacement..
By Bagheera in forum DVD & Blu-ray RecordersReplies: 21Last Post: 25th Oct 2008, 10:03
