I've just installed a new burner, which came with the Nero package, including Recode. Since I've never used it, I decided to give it a try. I used both programs on the same set of files, which I ripped with DVD Fab. While I haven't watched both disks all the way through, I have scanned them and they look very much alike. But, the big difference, was that Recode took less than one third of the time that Shrink did, to re-encode (transcode) the movie. Does it really work that much faster, or will I see some artifacts when I watch the disk on a screen larger than my computer? I have always used Shrink, but I will admit that I was impressed by Recode. It looks like the developer of Shrink has learned a lot during his years with Nero.
Yep, he improved the speed with Recode.
However, shrink has a little more functionality when it comes to your shrinking options.
I use them both. -
There's no difference in the encoders between these 2 programs. The difference is in the quality settings that Shrink has, which Recode does not have. If you have the quality settings set the same, they will encode at the same speed.
The main difference is in the use of the deep analysis in Shrink, which is effectively a 2-pass encode. Results will be markedly different if the compression is severe, but no different with less than 80% compression in most cases.
Nero Recode on a DVD player set
By Doopopmercury in forum Newbie / General discussionsReplies: 4Last Post: 15th Apr 2012, 21:19 -
How to quickly edit Blu-ray? Something like DVD Shrink or Nero Recode?
By peanutty in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Nov 2011, 17:43 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
Nero 9 Recode - DVD audio error
By ringo12 in forum Video ConversionReplies: 3Last Post: 22nd Nov 2009, 18:39 -
Has anyone switched from dvd shrink to nero recode
By ultraman36 in forum DVD RippingReplies: 3Last Post: 5th Sep 2007, 00:45
