Alright, I have been using VDub for about 5 months with no problems...I love the program...but here is the problem I just started having. VDub locks up at the end of every capture that I do above 200 frames...no matter the res. 352x240, 640x480, 720x480 ALL of them lock 2K up with no hope other than hitting my reset button! I reloaded 2K...same problem...I got 1.4.8...same problem...anyone ever run into this problem?????
My System:
AMD 950 Duron
512 MB RAM
10 Gig IBM Deskstar (OS)
60 Gig IBM Deskstar (Cap)
Pinnacle PCTV
Please! Please! This is really stumping me!
You should check the bottom of the capture window. Some codecs do postprocessing.
This is especially true of non-mjpeg and older codecs. VirtualDub's capture window will show 'writing frame #' whatever until it finishes.
Newer codecs like Intel Indeo 5.11, DivX and all mjpegs don't have this problem. -
Ummmmm, ok. I am using HuffyUV, but have tried PicVideo, uncompressed, etc.....this happens with all of them. Here is what I get at the bottom:
8917us jitter, 8917us disp, 85801K total, spill seg #1, 0/0
Let me reiterate...VDub LOCKS UP. I can't end the task, I can't end the process, I can't end the process tree. When I try to restart with the start button, it tells me that VDub task must be ended to reboot, it tries to end it, and fails. Then I must reach down and hit my RESET button. Anyone else with something useful???? -
Boy, that was bad. Didn't really mean to sound like a dick there...I hate guys like me...and they never get any help...just pissed at VDub! Sorry mamboman...
Ok, I guess no one is reading this post anyway, but I have reached a new level with this capture thing....VDub only locks up when I try to grab 16-bit, stereo sound at 176 kb/sec....anyone ever have that problem before? Any help will be much appreciated.....thanks
Trouble with capture - ATI HD750/VDub
By TB Player in forum Capturing and VCRReplies: 10Last Post: 23rd Jan 2012, 17:37 -
Vdub: Screen Capture
By dylz in forum Capturing and VCRReplies: 6Last Post: 12th Jan 2011, 16:24 -
VDub setup for VHS Capture
By HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 03:48 -
split fields in vdub capture
By greenbag in forum Capturing and VCRReplies: 0Last Post: 18th Jan 2009, 22:50 -
Capture Locks on the first
By depsci in forum Newbie / General discussionsReplies: 4Last Post: 2nd May 2008, 14:21
